Re: Amp meter showing discharge
Posted by GD720D on August 28, 2007 at 15:39:39 from (66.226.101.124):
In Reply to: Amp meter showing discharge posted by 59 Cub Lo-Boy on August 28, 2007 at 11:59:08:
Might battery. Might be hooked up wrong. All 6 volt systems were positive ground. This would make the amp gauge work backwards
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
