Posted by Bob Kerr on August 15, 2007 at 07:12:58 from (64.12.116.73):
In Reply to: Re: gear noise posted by Bob Kerr on August 15, 2007 at 07:09:01:
You can get to the input shaft through the hole in the belly where the pump is. You have to take out the pump, undo the clutch coupler and remove clutch shaft. The input shaft is the upper one and 3 bolts will remove it. You might also have to pull off the belt pulley and look through the hole there to see or line up the shaft again after putting it back together.
Today's Featured Article - Tractor Profile: Oliver 70 Row Crop - by Staff. The Oliver 70 was part of the "Fleetline Series" and was manufacturered from 1937 to 1948. The row-crop configuration could have either dual or single front wheels. The Oliver 70 was also offered in the standard, orchard and industrial configurations. The tractors were sold in Canada. An early advertisement states "Power when you want it - power when you need it - power to help put in crops when field conditions are right and time and help are limited. That's the power you'll find in an Oliv
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
