Re: M Farmall locked up
Posted by El Toro on July 21, 2007 at 04:20:05 from (205.188.117.137):
In Reply to: M Farmall locked up posted by Mez on July 20, 2007 at 19:26:01:
I would pull the head and remove all the water from the top of the pistons. If there's a lot of rust in the cylinders I would run a cylinder hone into each cylinder to remove the rust. Then pour ATF into each cylinder and let it soak. If all the wheel rocking and starter bumping doesn't free the pistons I would drain the oil and remove the oil pan and loosen all the bearing caps. I would remove one of the rod caps and use a piece of 2X2 oak and a big hammer and tap on that rod to drive out the piston. I did this on an A Farmall, but I pulled the engine and I had the pistons out the same day I got the tractor. Several pistons came out with the sleeves. Some heat from a torch freed the pistons from the sleeves. I only needed the old rods for a new sleeve kit. The crankshaft didn't look too great. but it only needed to be polished and needed .002" undersize bearings. Here's a picture of the A taken in 1976. Hal
Home
| Forums
| Order Support
Today's Featured Article -
Tractor of the Month - by Staff. decals, dependin upon the configuration of the parent company International Harvester in the year of production. For the purpose of this article, we will refer to the tractor as simply a "Farmall Cub". This little tractor was aimed at the needs of the small-acreage farmer - farms of 40 crop acres or less and truck gardens, or for larger farms that needed an extra tractor. Seven or eight implements were initially designed for it: Plow, Disc, Backblade, Sickle-Bar
... [Read Article]
Latest Ad:
1952John Deere MT tractor
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
