Re: M Farmall locked up
Posted by Janicholson on July 20, 2007 at 20:06:58 from (71.87.39.51):
In Reply to: M Farmall locked up posted by Mez on July 20, 2007 at 19:26:01:
Tell us much more, so we can make it operational again. If it was being started, and it will no longer turn over, the fix is to put it into high gear, and rock the devil out of the tractor forward and back. this motion releases a jambed starter. (so does looesning the bolts, but this is us ally much quicker. Letus know the circumstances. JimN
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: John Deere 750 Diesel Yanmar J80TU engine. pistons and rings replaced when discovered crankshaft was bent. 3995 OBO Pictures available upon request [More Ads]
