what is the number one cause of this?
Posted by aaron nadolson on June 27, 2007 at 13:27:19 from (67.140.97.129):
I replaced flow control spring and seal on hydraulics, added fluid to proper level, started tractor, worked for a minute and then lost all hyrdaulic pressure on a farmall 300 utility with power steering. What is the most likey cause? How do I fix it. Thank you!
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
Latest Ad: 65 Massey FERGUSON DIESEL [More Ads]
