Re: U-2 power unit
Posted by gene bender on February 12, 2007 at 03:51:55 from (67.55.226.214):
In Reply to: U-2 power unit posted by bobgfla on February 11, 2007 at 18:01:04:
There are3 small changes but the crank and stuff are the same. Block is different as the starter went in from the front there will be a dipstick and probably a plate for a fuel pump. Internally all parts will fit.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
