Re: A Brakes
Posted by gene bender on February 06, 2007 at 08:23:26 from (67.55.226.214):
In Reply to: A Brakes posted by Roger Mills on February 06, 2007 at 06:52:06:
I would do the drivers side first then you are familiar with how they work and how to take apart. Remove tire and center sec with a cherry picker as the cast center weighs 147lbs. After getting that out of the way you can remove the final drive where it bolts to the cast diff shaft housing. Using the cherry picker again you can remove the final drive easy. Blocking left side is important to remove the final drive. Mite need to replace the seals at this time remembering that the diff shaft comes out the wheel side of the final drive this will require removing the brake drum. Just be carefull and shore up the tractor careful before removing the final drives. If you dont have a cherry picker i would rent one or borrow as it beats lifting. Final drives dont need to be taking apart just remove the diff shaft to do the seals.
Today's Featured Article - Buying your first tractor: Choosing the right one - by Chris Pratt. They cost less than the tax on a new tractor (at least where we live). They have the weight to do the job. They are simple and understandable. They even have a history and can be restored to become a major source of pride and enjoyment. But how do you know what to buy and how do you make the right purchase? There is a surprising number of machines available in every shape and size imaginable. Like most things in life, your needs have a lot to do with wh ... [Read Article]
