Need tips gettin PTO fixed.
Posted by J Muehring on January 04, 2007 at 03:20:42 from (209.240.206.210):
The PTO on my Farmall 400 is gaining oil so I assume the inner seal needs to be replaced ? Any special heads up on that repair or is it fairly easy ? How high should I get the rear end of tractor up so all the Hytran doesnt run out ? Ive changed Hytran so I dont want to lose any on the shop floor. Thanks ,Jeff
Today's Featured Article - Engine Basics: Spark Plug Cleaning - by Staff. Cleaning procedures: Brush or blow dirt from around the spark plug base. Remove the plug with a correctly fitted wrench. Examine the porcelain insulator and points. If the insulator appears to be melted or blistered, cracked or broken, and the points seem unduly burned it is evident that the plug is operating too hot and it should be replaced with a colder plug. If the plug is fouled excessively with carbon it apparently is operating too cold and it should be replac ... [Read Article]
