Re: McCormick W6
Posted by Janicholson on December 28, 2006 at 08:49:54 from (66.188.149.191):
In Reply to: McCormick W6 posted by jacksonduper236 on December 28, 2006 at 04:26:00:
The "W" tractors are not as handy for utility use as same year C-H-M (opinion) the driving position, difficult steering, and ease of mounting the seat, are slight drawbacks. If it is running well, and has been warmed up w/o smoke, pulls well, then I would say 1200-1500$. If it has been converted to live Hydro, and the electrical system is not a rats nest, add 250. JimN
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
