Re: hydro fluid leaking out of my 51 h
Posted by Janicholson on December 20, 2006 at 15:21:28 from (66.173.50.116):
In Reply to: hydro fluid leaking out of my 51 h posted by city farmer on December 20, 2006 at 14:29:38:
Mark, that is not an issue that requires splitting. (if it is indeed Hydro oil) The pump comes out of the bottom by removing all the pipe fittings and control lever. Turning the drive coupling to it from the trans countershaft so it is vertical, then lowering the pump on a floor jack. It is cool to operate the tractor without the pump, just cover the hole with a 16ga sheet metal plate. The pump seals are available, and not hard to repair. Keep us in formed. JimN
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
