Re: How To Operate a T/A
Posted by Ben Shipley on November 14, 2006 at 18:11:18 from (68.235.177.52):
In Reply to: How To Operate a T/A posted by City-Boy McCoy on November 14, 2006 at 18:06:33:
Mike
On newer tractors, you can go ahead and pull back the T/A without clutching, I assume it is the same on the older ones as well. When you are ready for the high side, go ahead and ease it forward and away you go. In my experience, DO NOT use the T/A to hold you back going down hill. Leave it in the high side and drop a gear. Pulling it back to the low side to hold back will tear it out sooner or later.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
