Re: 350 utility hydraulic problem
Posted by chuck46 on November 10, 2006 at 19:58:04 from (205.188.116.133):
In Reply to: 350 utility hydraulic problem posted by Ed Hir on November 10, 2006 at 14:34:27:
Hi, The oil being thrown out is usualy caused by air trapped, possibly in your cylinders. Clean the suction sreen and operate it with less oil for a while and see if it gets better. Most common problem with the valves is the shaft that changes them from double acting to single is not fully located in either position. Good Luck, Chuck
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
