Re: Live Hydraulic conversion for an H???
Posted by chuck46 on October 24, 2006 at 09:02:50 from (152.163.100.65):
In Reply to: Re: Live Hydraulic conversion for an H??? posted by glennster on October 24, 2006 at 07:40:36:
Hi, I have had a live pump on my 41 H for over 30 years, it works very well. You will need a pump from a Super H 300 or 350 and the port block bolted to the bottom of pump. To mount the pump, two of the holes will match, I drilled and threaded a third and made a simple clamp for the top left. You will need to rework the pipes from the port block to suit you. Mine has been used a lot with no problem from the timing gears. Good Luck, Chuck
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
