Re: Fixing Up A Farmall A
Posted by gerrybn on October 11, 2006 at 13:32:15 from (81.153.176.71):
In Reply to: Re: Fixing Up A Farmall A posted by Marty Johns on October 11, 2006 at 06:45:15:
marty,another way is to compare # against tractor registry on research(look up model and use # to find yr.) possibly Bit more inaccurate though!
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
