Re: 1066 Torque Range
Posted by JJK on September 10, 2006 at 06:40:38 from (216.189.131.145):
In Reply to: 1066 Torque Range posted by Rick in Ont. on September 10, 2006 at 05:10:55:
There are two different pumps for these engines. One runs at 2400 and the other at 2600. There is a little tag on the injection pump that gives it rpm range if you care to take a look to make sure that yours is a 2600. They will handle running that fast but thats up to you how to run your tractor. As far as the hp thats just fine running 147. The only problem with putting a super amounts of hp all you may end up doing is find the weak link in the drive train eventually.
