Re: IH--H4 Magneto Questions--Need Help!!!
Posted by MAGMAN on September 04, 2006 at 17:23:02 from (67.142.130.29):
In Reply to: IH--H4 Magneto Questions--Need Help!!! posted by Pappy on September 04, 2006 at 16:05:20:
NO PAPPY,
That is not right, It should trip at about between 1 and 2 oclock. The best way to time a mag is to put motor on top dead center compression #1 trip the mag just past #1 on the cap go a wee bit farther with the motor and install then turn the motor over backwards about a half rev then back to timing mark turn mag out wards untill it trips and tighten.
JON
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
