Farmall Tractors Discussion Board
Re: Re: Re: Super A misses
Posted by ltf in nc on January 22, 2000 at 21:01:34 from (206.228.213.54):
In Reply to: Re: Re: Super A misses posted by Daniel on January 22, 2000 at 16:45:09:
While you are checking all the above listed items check the compression. It could be that you have a broken valve spring or a sticking valve. Post your findings so that all of us can learn.
Post A Followup
: Re: Re: Re: Re: Super A misses
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
