Re: Super A oil change question
Posted by billde on July 21, 2006 at 18:43:59 from (66.249.53.208):
In Reply to: Super A oil change question posted by Mark (PA) on July 21, 2006 at 18:11:56:
By all means pull the pan, gaskets are cheap. If you find a lot of sludge you may also want to pull the valve cover.
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
