Re: LP tractors and storage
Posted by John A. on June 21, 2006 at 06:52:49 from (4.253.40.18):
In Reply to: LP tractors and storage posted by farmallkid1958 on June 20, 2006 at 21:44:00:
farmallkid, On LP tractors It doesn't make a hill of beans in difference! For there is NO solenoid fuel shut-off. Hence when you kill the engine for longer than saaay.....time to eat lunch, shut off thr valves. On the question of whether to simply kill the engine or burn the line dry. That may be more of a question to the quality of the LP system than personal prefference. ie.... For a bad diaphram can cause a flooded situation if the tank valve is left on. So shutting the valve off, then rolling the engine over, then open the valve (slightly) the engine will usually start, finish opening the valve and one is good to go. As a rule most LP systems will seep/leak out what is between the valve and carb overnight. Hope this helps! Later, John A.
Home
| Forums
| Order Support
Today's Featured Article -
Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
