Re: farmall b wont run after bad rain storm.
Posted by El Toro on June 17, 2006 at 15:12:43 from (64.12.116.65):
In Reply to: Re: farmall b wont run after bad rain storm. posted by RVaughn on June 17, 2006 at 14:10:39:
I would use a timing lite to set the timing. I use an inductive lite from Sears and you just clip the pickup over the plug wire. Yuo may need another helper while one handles the lite and the other moves the mag. Hal
PS: Chalk the flywheel timing mark so its easy to see.
