Cub is finally running
Posted by spray004 on June 11, 2006 at 20:48:03 from (24.179.43.228):
Well finally got the Cub running. I had to order a new Zenith carburetor from this website. It was definitely not a direct bolt on. I had to modify the choke so that it would work with the choke lever and I had to add some washers to the mounting bolts. It seems to run decent, but nothing spectacular. If I pull the throttle all the way back it barely runs so i'll have to work on the throttle lever next time I get a chance. Also the tractor is very hard to start without using starting fluid. I'm thinking that maybe the carburetor is out of adjustment and that's what is causing it to have a hard time starting.
In any case 1 down, 3 to go. The 706 just needs batteries, but $70+ each is a hard bite to swallow for a tractor that won't be used all that much. The B just has a weak spark and the Super C has a lot of problems (bad carb and clutch is stuck to the flywheel).
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
