Re: Farmall C Oil Pressure?
Posted by El Toro on June 03, 2006 at 06:48:53 from (205.188.116.133):
In Reply to: Farmall C Oil Pressure? posted by Smith1 on June 03, 2006 at 05:24:54:
I would start by changing the oil and filter. Then run the tractor and then see what your pressure is. The oil pump may have some wear and
the rod and main bearings may be worn too. Close tolerances on these bearings will give you good oil pressure. Hal
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
