Re: gonna BURN this dang H !!!!!!!!!!!!!!!!!!!!!
Posted by jal-SD on May 11, 2006 at 06:49:42 from (71.32.34.112):
In Reply to: gonna BURN this dang H !!!!!!!!!!!!!!!!!!!!! posted by Farmallkid From Ont, on May 10, 2006 at 16:45:48:
Have you disconnected the mag ground wire & tried it? Sometimes the mag ground wire shorts out through the insulation, you often can't see where it is shorting & it might not do it all the time. Try it with the ground wire disconnected & see what happens. (My $0.02 worth. jal-SD)
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
