Re: 350D won't start?
Posted by Bill46 on April 24, 2006 at 10:14:38 from (63.65.68.27):
In Reply to: 350D won't start? posted by Cotton Picker on April 24, 2006 at 07:01:16:
CP, make sure the injector pump is not loosing it's prime by seeping of leaking fuel after you shut it down.
Also, it may be the fuel shutoff sticking a little in the head or the pump. The linkage on the outside looks good...but it sticks inside the pump.
I had the same problem with dad's old 350D. Hot it would most times start right up...but one time it did not and it gave me fits. I got a can of fuel and using an electric pump and rubber line forced fuel into it. It fired right up. Darn pump was seeping past the o-rings inside.
I had it rebuilt and it fires fine now...but sometimes the linkage inside still sticks. If I tap it with a wooden handle screwdriver...I can hear it move inside. It fire right up then.
My 2 cents.....
Today's Featured Article - Tractor Profile: Case VA Series - by Staff. V, VC, VI and VO). Althouh the Case VA looked much like the V, it shared no major components with its predecessor. Except for military units, the production of the Case VA was interrupted in July of 1942 due to World War II. It resumed again in 1944 and continued until 1953. It started up briefly later on in 1953 and continued on a very limited basis until 1956. The VA Series included the following models: VA: Fixed front wheel tread VAC: ... [Read Article]
Latest Ad: Wanted to buy model 65 massey ferguson 65 diesel [More Ads]
