Re: 3588 Question,s?
Posted by chadd on April 06, 2006 at 12:07:13 from (155.92.31.140):
In Reply to: Re: 3588 Question,s? posted by the tractor vet on April 06, 2006 at 09:32:41:
Yeah, for some reason I thought it was called Power Priority Hydraulics, but you are right, the service manual says PFC.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
