Re: Radiator Top Hose
Posted by PAULIH300 on February 21, 2006 at 16:08:27 from (205.188.116.133):
In Reply to: Radiator Top Hose posted by Tweeter on February 21, 2006 at 11:39:08:
Sounds like its building pressure at the top hose,thats either a plugged radiator or a bad head gasket.I had an old Chrysler with a plugged radiator many years ago....it would pop little holes in the top tank like gysers all the time.The pressure had to go somewhere afterall.The top hose swelled up twice normal size.Replacing the radiator solved the problem....well,that problem anyway.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: WANTED IH C200 gas engine — complete running motor Wanted complete used IH C200 gas engine in running condition for an International 574 gas tractor. My block has a hole in it and is dead, so a rebuild kit wont do it — need a whole running motor. The C200 also came in the 544 and 674 gas trac [More Ads]
