Re: IH 300 U
Posted by Janicholson on February 10, 2006 at 14:11:03 from (66.173.50.126):
In Reply to: Re: IH 300 U posted by coaltrain on February 10, 2006 at 13:00:44:
The 300 is wired in the same manor as the diagram for the key switch delco alternator diagram (except)
The solenoid is three pole eliminating the balast resistor bypass wire Note 4 on the diagram. Also the regultor will be wired the same as the super HM 6volt diagram. The Bat wire from the regulator goes to the location (in the other diagram) where the big wire attaches to the amp meter.
The voltage regulator wires are longer and the regulator is not attached to the gen, but the wires are connected that way.
If you still have problems let us know.
JimN
