Re: coil resistor
Posted by captaink on February 08, 2006 at 07:17:20 from (66.115.214.56):
In Reply to: Re: coil resistor posted by John T on February 07, 2006 at 16:20:57:
I like to change the switch on the starter to one that has a small terminal on the side that delivers current when the starter is running. I run a wire from there to the coil side of the resistor. That way I have a 12 volt start 6 volt run setup and it compensates for the voltage drop when the starter is engaged. I know on a C this isn�t a lot, but when you get to an M and it�s -20 F it becomes a big deal.
