Re: 240 utility and ih2000 loader?
Posted by Hugh MacKay on January 26, 2006 at 03:22:58 from (216.208.58.120):
In Reply to: 240 utility and ih2000 loader? posted by KevinH on January 25, 2006 at 17:11:26:
Kevin: I don't think I would want that loader on a 240U, particularly if the tractor is an ag version. That 2404 in the photo while it is much the same tractor as yours, will have a lot heavier front end.
If you notice one other item in the photo, the 2000 loader arms are designed in such a way they give lots of reach even for loading large trucks where loader has to be raised full height to reach over the side. The main problem with this design, is when loader is lower than 5' off the ground, it extends much further beyond the front axle. Inches from front axle count bigtime when that bucket is full of dirt. You will also find a 2000 loader or any loader designed for reach will require a lot more room, especially noticable in tight corners.
It all depends on what you wish to use a loader for. If it's yard work where you are manuvering around buildings, trees, vehicles, etc., a loader designed so bucket is much closer to tractor front will be much better. If your loading big trucks or any other high and long reach applications the a 2000 or like loader is for you. Personally I would put a much heavier tractor than a 240 under a loader for that latter use. I had a 560, with a 1/2 ton counter weight under my 2000 loader.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
