Re: Small imported alternator...one wire?
Posted by John T on December 11, 2005 at 18:32:35 from (66.244.90.98):
In Reply to: Small imported alternator...one wire? posted by R-cubed on December 11, 2005 at 16:20:48:
R, The Delco you hear so much about (10S1) is actually a 3 wire unit, but it is internally regulated. While a true ONE wire is easier to install, some require a higher RPM before they kick in and can cause a teeny trickle discharge on the battery (could use a diode if neecessary). Most all require Negative ground which means you may have to do some easy re configuring for Negative ground if youre at positive now. The smaller one wire (may be foreign) units fit under some hoods a lot easier then the Delco 10SI
John T
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
