Re: Super A or C engine casting number
Posted by Keith-OR on November 28, 2005 at 09:11:10 from (207.200.116.203):
In Reply to: Super A or C engine casting number posted by Gary Hunter on November 28, 2005 at 08:00:21:
Gary, we have a C-123, casting # 366295 R3 that came off of a IH baler that was going to be scraped. Here is a couple of things that I noticed that are different with the engine off of the baler, 1.it has a tipstick on right rear side just in front of bellhousing flange and just behind oil filter, 2.looks to have place to put on mechanical fuel pump. 3.throat on intake is shorter than on tractor manifold. 4, Casting is different on right rearside as to allow for starter, since the starter comes in from the front of bellhousing rather than from the rear as one on tractor..HTH identify the one you are looking at
Keith & Shawn
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
