Re: reinstalling old piston and rings
Posted by RM on November 21, 2005 at 15:30:46 from (65.71.202.161):
In Reply to: Re: reinstalling old piston and rings posted by El Toro on November 21, 2005 at 15:16:44:
The main concern is to make sure that you install
the rings on the same piston they came off and in
the same order ie. top compresion, bottom comp. then oil ring ,also you install the piston in the same cylinder it was in orginally. Follow the book on clocking the rings. Rings usaully do not rotate. The reason for reinstalling everything the way it came apart is because it has formed a wear pattern. Good Luck
Post a Followup
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Looking for a minneapolis moline zts [More Ads]
