charging system - stumpted
Posted by jeg on November 19, 2005 at 08:01:32 from (207.200.116.203):
I am hoping you can help me. When my tactor is running I check the voltage at the battery and at the "A" on the generator - it only shows battery voltage ( no charging ). If I gound the "F" on the genrator she starts charging. If I ground the terminal on the VR it shows charge. Here is my problem. If I check continuity from the VR terminal to the body of the VR it shows it is continious ( cleaned the areas very well when I mounted the VR to make sure it has a good ground). If it shows continuity why does it require another ground to start charging?? Is the VR bad??
Thanks
Post a Followup
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
