Re: 574 sputters
Posted by El Toro on November 13, 2005 at 04:36:12 from (64.12.117.13):
In Reply to: 574 sputters posted by Tony in LH on November 12, 2005 at 21:01:29:
Are the plug wires copper? You need to pull the
coil wire from the distributor cap and place within a 1/8 to 1/4" of a good ground. You can hold it with a pair of insulated pliers so it doesn't bite you. Then have someone to attempt
an engine start and watch the fire from that coil wire. Should be nice and blue. Is this a -
negative grounded battery? If it is, the negative
terminal on your coil; the wire from this terminal should go to your distributor. Hal
PS: When you replace the plug wires did you replace one at a time? Your plug wires should be installed like this on the cap if rotor turns CW.
2-1
4-3 The firing order is 1-3-4-2
Post a Followup
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
