Re: SC steering housing leak?
Posted by Haas on November 09, 2005 at 06:01:10 from (12.65.7.152):
In Reply to: Re: SC steering housing leak? posted by leon on November 09, 2005 at 04:04:29:
Were the bearings good with no play. Any play and you will have a leak. The main shaft must have a smooth good surface for the seal to run on. I've done two of these and on one of them, I used a "Speedy Sleeve" to give a new surface for the seal. The installation tool that came with the sleeve would not work, had to make one out of some PVC pipe. No leaks on that one, the other had a better main shaft. It seeps just enought to catch some dust. Also, did you check the seal holder very carefully. These are frequently cracked. I had to replace one of these.
Post a Followup
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
