Re: FARMALL A
Posted by El Toro on October 24, 2005 at 16:53:30 from (205.188.117.73):
In Reply to: FARMALL A posted by RICK IN VERMONT on October 24, 2005 at 16:29:38:
When it quits, see if there's fuel in the carburetor. Remove fuel line at carb and check for a good flow, just a trickle your tank may needs to be cleaned of rust & dirt. Could be crud in the carb too. If fuel is ok I would change the condenser as mentioned. Check for fire at your sparkplugs, you will need someone to crank engine when checking this. How long after it quits will it restart? Hal
Post a Followup
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
