Re: Missing screw
Posted by RustyFarmall on October 14, 2005 at 06:18:55 from (216.248.75.159):
In Reply to: Missing screw posted by OBie on October 14, 2005 at 05:53:12:
Most likely the screw got pulled into the motor and has imbedded itself into the top of a piston. If the engine is running fine now, and you don't hear any unusual ticking sounds, then I wouldn't worry about it. There is no way it could have just fallen out provided the intake tube from the air cleaner is in place. And even if you were running the tractor without the air cleaner, the screw would still have been sucked into the motor.
Post a Followup
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
