Re: McCormick W6 Hydraulics
Posted by 26Red on October 07, 2005 at 09:42:49 from (170.92.100.2):
In Reply to: McCormick W6 Hydraulics posted by Allan lance on October 06, 2005 at 18:56:30:
You can add live hydraulis off the distributor drive- Like the super M's and super W6's, but that is expensive. You would be better off getting a pump from Northern Hydraulic or Force America and mount it off the front of the engine with the shaft going thru the hand crank hole. Many T-6 and TD-6 dozers are set up this way.
Then you would have to add a tank to hold the hydraulic oil and hydraulic control valves to run you implements.
Post a Followup
Today's Featured Article - It Can't Be Done! - A Tractor Story - by Neil Campbell. I'll never forget the time back when I was a boy baling hay on our Farm in Big Rapid, Michigan. The most memorable event that took place was a trip up the steepest incline on the farm pulling an old New-Idea baler with a pony-motor for power and a haywagon. I had just talked my Dad into buying an old John Deere B with 6-speeds ahead and I was real proud of it, except it was a little smaller than the Case tractor that we normally ... [Read Article]
