Re: Should I or shouldnt I (kinda long)
Posted by farmallhal on September 14, 2005 at 07:51:44 from (64.24.35.16):
In Reply to: Re: Should I or shouldnt I (kinda long) posted by gene (missouri) on September 13, 2005 at 19:08:09:
Gene, I have the same problem on my M as it seems to leak a few tablespoons of anti-freeze over the course of a year. I've had the tractor a little over a year and first noticed the anti-freeze when I cahanged the oil after getting it home. I've been keeping an eye on it by opening the drain plug and letting it seep out over night. I retorqued the head to 110 ft-lbs. (factory spec.) and got a 1/4 turn on several of the nuts. Don't know if that took care of it yet or not. I purchased a couple of bottles of "Bar's Leaks Radiator Stop Leak and Conditioner" yesterday. It states on the container treats up to 4 gals. The M system is a 6 gal. system and was going to put two 10 oz. bottles in it. Does all of this sound right and thought I would take it for a good drive of maybe up to an hour to really warm it up.
I'll be watching for your posts relative to this matter as it appears you are a person that has "been there - done that". Where are you located in Missouri as I live up near Rolla south of I-44? Have a good one and thanks for any information you can provide. Hal
Post a Followup
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
