Re: farmall h will not start
Posted by El Toro on August 14, 2005 at 17:49:06 from (205.188.117.73):
In Reply to: farmall h will not start posted by bigal 1 on August 13, 2005 at 14:11:45:
You need to check how your mag is grounded when the engine is shutoff. That could be your problem
for no spark. They could use a switch or a rod
that would ground out your mag. You need to inspect the mag for this. If a switch is used
an ohm meter can be used to see if the wire is
grounded on one side of the switch. One position
could be the start position and the other to ground the mag. You don't use ignition voltage
with a mag. With battery ignition when you shut
off the ignition switch it kills the voltage to the points and coil. The mag is always grounded.
That's just used when stopping the engine. Good Luck, Hal
Post a Followup
Today's Featured Article - Talk of the Town: What's in Your Tractor's Toolbox? - by Staff. This recent discussion on the Tractor Talk discussion board here at the on-line magazine drew so much response and proved to be so interesting that we wanted to share it with you here. The names of the people participating in the discussion have been left out to "protect the innocent" (to quote a once-popular television series). ... [Read Article]
