Re: farmall h will not start
Posted by Rodger in Sabula on August 13, 2005 at 17:05:41 from (69.48.22.112):
In Reply to: farmall h will not start posted by bigal 1 on August 13, 2005 at 14:11:45:
Yes, you can check the continuity through the coil. It is best if you disconnect the condenser again, then measure from the coil wire that connects to the condenser both to ground and to the high voltage connection on the coil (or to the connector on the coil cover). You should see very low resistance through either test. If you show an open, the coil will need to be replaced.
Post a Followup
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
