Re: Farmal l - H M Seat pan
Posted by CNKS on July 30, 2005 at 08:47:30 from (204.249.178.138):
In Reply to: Farmal l - H M Seat pan posted by Don L C on July 29, 2005 at 20:46:19:
As stated, I think all available springs are the stiff ones. For myself, I would like a softer one, as I weigh 100+ lbs less than you, the spring on my Super H doesn't give enough. The hinge feature is separate from the seat, salvage is your best bet. If NE Cowman does not have the hinge, Mike at Steel Wheel Ranch probably does--785-548-7437--such items are usually well-worn, though.
Post a Followup
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha ... [Read Article]
