Re: 560 GAS WEAK SPARK POPPING AT CARB
Posted by El Toro on July 25, 2005 at 03:56:52 from (152.163.101.13):
In Reply to: Re: 560 GAS WEAK SPARK POPPING AT CARB posted by JREX on July 25, 2005 at 02:01:10:
I think the engine will start with a bad resistor, but it quits once you release the starter switch. These were used on speed boats too, they used a lot of auto engines in boats and those resistors cause starting problems. I think you need to check your timing to make sure that it is ok. You said you have a weak spark at the plugs, here's a procedure for checking your ignition system, 1. Check for battery voltage at the coil. Use a test lite or volt meter. 2. Check for battery voltage at the points. Use a test lite or volt meter. 3. Remove distributor cap, rotor & points cover; remove the coil wire from the distr cap & put within 1/4" of a good ground. 4. With points closed & ignition switch on, snap the points open a few times and watch for spark at the coil wire end. Should be a hot spark. 5. If no spark is present: you may have dirty points, a bad condenser or a bad coil. Coil primary wire must be attached to - post on coil if battery is - grounded. If battery is + grounded then the primary coil wire must be attached to the + post on the coil. Hal Make sure those points are set at .020" and run some 320 emery cloth through the points when closed. May have a coating on them.
Home
| Forums
| Order Support
Today's Featured Article -
Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor
... [Read Article]
Latest Ad:
Late 50s early 60s international harvester 560 with cultivator
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
