Re: 560 GAS WEAK SPARK POPPING AT CARB
Posted by El Toro on July 24, 2005 at 16:00:58 from (205.188.117.73):
In Reply to: 560 GAS WEAK SPARK POPPING AT CARB posted by JREX on July 24, 2005 at 10:46:04:
You need to remove No1 plug and hold your thumb over the plug hole while someone hand cranks the
engine over until you feel compression against
your thumb. Slowly crank until your timing marks are aligned with one another, then remove distr. cap and see where rotor is pointing, should be at No1 plug wire in the cap. If off, something may have thrown the ignition out of time. Stipped a gear or the timing gear may have slightly sheared the woodruff key on the camshaft causing the ignition to be out of time.
Hook a timing light to No1 plug and see where your timing mark is when cranking the engine with the starter with the ignition switch on. It may have enough fire to trigger the light. Coat the timing mark with some chalk so its easily visible.
Hal
Post a Followup
Today's Featured Article - More Memories of a Field Service Engineer - by Brian Dye. Introduction: The author worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 he became a dealer manager and finally left the dealer net in 1975 to run his own electronic design and manufacturing company. [Editor] We live right in the middle of Norfolk. The dealership that I worked for sold Fordson Tractors from the 1920's and some of t ... [Read Article]
