Re: Farmall c crank pulley
Posted by Pharmall on July 11, 2005 at 08:51:42 from (68.9.106.167):
In Reply to: Farmall c crank pulley posted by Michael Kinnard on July 11, 2005 at 07:51:48:
El Toro is correct. The puller shown in the link he gives is the
best way to remove the pulley. If it is an original '48 or '49,
there won't be a set screw, but look anyway. The pulley is just a
press fit with a Woodruff key - not tapered or screwed on.
There is a 1/2"-13 tap in the end of the crankshaft. You might
have to clean a bit of dirt out of the end to find it. Screw a long
1/2-13 hardened bolt in the end of the crank, and push against
the head of the bolt with the hydraulic jack as shown in the
picture. I have the dimensioned drawings for a similar puller if
you would like them. Used it on my '48C recently. Jeff
Post a Followup
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in. ... [Read Article]
