Re: Ignition Exhaust Advice 43 H
Posted by Bob M on July 01, 2005 at 04:25:26 from (151.190.254.106):
In Reply to: Ignition Exhaust Advice 43 H posted by ChrisL on July 01, 2005 at 03:41:05:
Chris � My recommendation is to buy a new 6 volt coil and battery and return the electrical system to original. So long as the electrical system is in good shape (especially the battery cables), your H will start reliably on 6 volts. --- From your description it sounds like your H is equipped with a distillate manifold. The busted piece is called the �exhaust pipe� (part #6 713 D) � it will be difficult to find a replacement. The easiest solution is to replace the entire manifold assembly with a gasoline manifold (uses a standard 2� threaded pipe nipple for the exhaust pipe which can be replaced in the unlikely event it rusts thru or gets bent). Figure on spending $120 or so for a new aftermarket gas manifold. Or you might find a good used one at a boneyard. But you will now have a solid muffler mount, and it will give the engine a bit more power as well.
Home
| Forums
| Order Support
Today's Featured Article -
My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that�s wha
... [Read Article]
Latest Ad:
1965 International Harvester McCormick Farmall cub tractor 2,500. Two owner tractor. My grandfather bought new in 1966, then we inherited it. Have all the paperwork original manual and all maintenance records. It starts and moves. Comes with underbelly mower, plough, and some other attachments.
[More Ads]
Copyright © 1997-2026 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
