Re: Hugh, Your 1066
Posted by MN Scott on June 12, 2005 at 10:44:07 from (206.9.216.26):
In Reply to: Hugh, Your 1066 posted by Allan in NE on June 12, 2005 at 09:23:58:
Allan,
My 1066 dyno's at 162 horse. It's a 1973 model with 3100 hours. Still has the factory pump with the factory warranty seals intact. Dad bought it new so I know everything is original. The block is stamped DT414. I never run out of power just traction.
Scott.
Post a Followup
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
