Re: 1942 farmall h problem
Posted by EricB on May 25, 2005 at 06:22:06 from (216.209.84.11):
In Reply to: 1942 farmall h problem posted by Andy(PA) on May 23, 2005 at 06:40:33:
If you are running only 83-83-83-60 and have just rebuilt the head I would look seriously at the rings and sleeves.
Have you done a wet dry compression test. ie: checked compression normally then put a 1/2 oz of oil in each cylinder and tested again. If there is a difference then your rings are in question. The oil seals off any small gap along the wall long enough to get a reading. If there is no change I would check the head gasket and speak to the guys that rebuilt your head.
Post a Followup
Today's Featured Article - Horsepower Defined - by Staff. Indicated Horsepower This represents the power developed in the enine cylinder as obtained from the pressure in the cylinders. This is pressure obtained from an indicator which shows cylinder pressures. Indicated horsepower does not represent the actual useful power delivered by the engine. Brake Horsepower This is the actual horse power delivered by the engine to the shaft. It is equal to the "indicated horsepower" less the friction of the engine. It is useful hor ... [Read Article]
