Re: 1942 farmall h problem
Posted by RustyFarmall on May 23, 2005 at 07:15:37 from (207.32.13.231):
In Reply to: 1942 farmall h problem posted by Andy(PA) on May 23, 2005 at 06:40:33:
I suppose it is possible that manifold could cracked internally but I've never seen it happen. Are you sure the points are gapped correctly? Is the ignition timing correct? If the timing is way off, either too slow or too fast, you will experience similar symptoms. Are the adjustments on the carb correct? If the load adjustment on the carb is set too lean the engine will miss, but usually this happens only under load. Last thought, are the pushrods bent? Is a lobe worn down on the camshaft?
Post a Followup
Today's Featured Article - Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to ... [Read Article]
