Re: M Charging Woes
Posted by leon worm on May 13, 2005 at 10:49:01 from (12.10.123.20):
In Reply to: M Charging Woes posted by Matthew(Mich) on May 13, 2005 at 09:14:01:
Matthew,
To confirm you gernerator is functioning properly, and to bypass the regulator, you can ground the field terminal of the regulator to make the generator outputs it"s maximum. When this terminal is grounded and the generator is working properly you should see your ammeter go to approximately 10+ amps. Another suggestion is I beleive the output of the generator can be adjusted by moving one of the brushes on the generator. There should be a screw on the back side of the generator that secures the bruch in place. by loostening this screw slightly you can move the brush position around the armature to make the generator output more or less.
Post a Followup
Today's Featured Article - Tractor Generators - by Chris Pratt. As a companion to the articles on three-brush and two-brush generators, it seemed fitting that we should provide our readers with a description of how a generator works in lay terms. The difficulty with all those "theory of operation" texts is that they border on principles of electricity or physics and such. Since I know nothing of either, you will have to put up with looking at the common sense side of how generators work which means we " ... [Read Article]
